450 track loader backhoe steering clutch
JDMainer
Post by JDMainer » Sun Sep 07, 2014 9:13 am
I am a new owner of a 450 track loader backhoe. I am going over it and have an issue of normal right turn not happening. Right steering clutch seems to be not working. I have much more free travel in right steering lever than the left. This machine had been sitting unused for a few years. Is there a way to get it working without a major overhaul.
Post by jtrichard » Sun Sep 07, 2014 10:41 am
probably not.... sounds like the right clutch pack is swollen from rust ..can you get any pics in the steering box?
JDMainer
update on problem steering
Post by JDMainer » Sun Sep 07, 2014 12:21 pm
Removed access covers to both steering boxes. Left side appears dry as a bone. Right side had moisture. Drained about a gallon or so of water from drain plug. Throw out bearings are moving the same on both sides.
Post by jtrichard » Sun Sep 07, 2014 3:03 pm
you will most likely have to pull it down.... check out this post its not a loader but is a 450 http://www.jdcrawlers.com/messageboard/ ... highlight=
JDMainer
Post by JDMainer » Mon Sep 08, 2014 8:28 pm
Thanks for the information. That thread you linked will be very helpful when I do the clutch rebuild. I have a few rocks and stumps to dig before that happens.
