450 track loader backhoe steering clutch
I am a new owner of a 450 track loader backhoe. I am going over it and have an issue of normal right turn not happening. Right steering clutch seems to be not working. I have much more free travel in right steering lever than the left. This machine had been sitting unused for a few years. Is there a way to get it working without a major overhaul.
update on problem steering
Removed access covers to both steering boxes. Left side appears dry as a bone. Right side had moisture. Drained about a gallon or so of water from drain plug. Throw out bearings are moving the same on both sides.
you will most likely have to pull it down.... check out this post its not a loader but is a 450 http://www.jdcrawlers.com/messageboard/ ... highlight=
