350c running warm
350c running warm
Ran the machine for 15 min full throttle in 90* weather and when shut down it hissed and steamed a bit- damn gauge said 100* so that isn’t working……
I will check coolant level next time but I don’t know status of fluid
Anything else to check?
Troubleshoot the gauge?
- jimmydiesel
Re: 350c running warm
The radiator cap needs to hold the correct pressure.
Test or replace-this is more important than most people Realize.
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
440 ICD 831 Loader
440IC 831 Loader
thanks
i will check fluid and then try to test the gauge. i will research the cap requirements.
If you have access to a non contact temp sensor use that to get actual engine temps.
JD- 450C track loader
Serial #208336T
Serial #208336T
thanks-
this sounds dumb to ask but ......
would you shoot the radiator itself?
- jimmydiesel
Take a reading at the thermostat housing-where the coolant leaves the engine to go to the radiator.
That will be the engine temp. Clean the the dirt and oil off.
You can take a reading from the top and bottom tank on the radiator to get an idea how the radiator is working.
440 ICD 831 Loader
440IC 831 Loader
440 ICD 831 Loader
440IC 831 Loader
- jimmydiesel
If the thermostat is still closed (engine not at operating temp) check the block where the thermostat housing bolts on.
440 ICD 831 Loader
440IC 831 Loader
440 ICD 831 Loader
440IC 831 Loader
Better yet, if you have or can borrow, a thermal imaging camera. See if there are any hot spots which indicate a coolant passage blockage.
I typically shoot the head area found out my gauge was reading about 15/20 degrees warmer than actual. Started shooting all my equipment found out how lousy temp gauges actually are. Like was mentioned i did like to shoot the top/bottom radiator just for fun to see how well all that was working.
Serial #208336T
Serial #208336T
So I only had a min or 3 to look at machine so far but I did add a gallon and a half of fluid to the radiator-
machine has sat for a couple days and I checked it without starting and added-
will check gauge next but low on fluid doesn’t help
Will let it run next and check temps
