350c running warm
Gwilkrrs
350c running warm
Post by Gwilkrrs » Tue May 31, 2022 8:10 pm
Ran the machine for 15 min full throttle in 90* weather and when shut down it hissed and steamed a bit- damn gauge said 100* so that isn’t working……
I will check coolant level next time but I don’t know status of fluid
Anything else to check?
Troubleshoot the gauge?
jimmydiesel
Re: 350c running warm
Post by jimmydiesel » Tue May 31, 2022 8:27 pm
The radiator cap needs to hold the correct pressure.
Test or replace-this is more important than most people Realize.
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
Gwilkrrs
Post by Gwilkrrs » Wed Jun 01, 2022 4:14 am
thanks
i will check fluid and then try to test the gauge. i will research the cap requirements.
77 Ford
Post by 77 Ford » Wed Jun 01, 2022 7:02 am
If you have access to a non contact temp sensor use that to get actual engine temps.
JD- 450C track loader
Serial #208336T
Gwilkrrs
Post by Gwilkrrs » Wed Jun 01, 2022 8:52 am
thanks-
this sounds dumb to ask but ......
would you shoot the radiator itself?
jimmydiesel
Post by jimmydiesel » Wed Jun 01, 2022 9:18 am
Take a reading at the thermostat housing-where the coolant leaves the engine to go to the radiator.
That will be the engine temp. Clean the the dirt and oil off.
You can take a reading from the top and bottom tank on the radiator to get an idea how the radiator is working.
440 ICD 831 Loader
440IC 831 Loader
jimmydiesel
Post by jimmydiesel » Wed Jun 01, 2022 9:21 am
If the thermostat is still closed (engine not at operating temp) check the block where the thermostat housing bolts on.
440 ICD 831 Loader
440IC 831 Loader
Post by Stan Disbrow » Thu Jun 02, 2022 4:03 am
Better yet, if you have or can borrow, a thermal imaging camera. See if there are any hot spots which indicate a coolant passage blockage.
77 Ford
Post by 77 Ford » Thu Jun 02, 2022 7:28 am
I typically shoot the head area found out my gauge was reading about 15/20 degrees warmer than actual. Started shooting all my equipment found out how lousy temp gauges actually are. Like was mentioned i did like to shoot the top/bottom radiator just for fun to see how well all that was working.
Serial #208336T
Gwilkrrs
Post by Gwilkrrs » Thu Jun 02, 2022 6:51 pm
So I only had a min or 3 to look at machine so far but I did add a gallon and a half of fluid to the radiator-
machine has sat for a couple days and I checked it without starting and added-
will check gauge next but low on fluid doesn’t help
Will let it run next and check temps
Users browsing this forum: No registered users and 9 guests
