isolator
mikeintn
isolator
Post by mikeintn » Sun Sep 13, 2009 7:39 pm
Has anyone tried to have the lining put back on the isolator on JD 350B?
say like a place that does clutches and brake lining, seems like 800 is lot of money for a new one just for that little piece of lining :cry:
Michael
Johnschnall22
Re: isolator
Post by Johnschnall22 » Sun Jun 06, 2021 6:16 am
Any luck with this? I'm in need right now..
Johnschnall22
Re: isolator
Post by Johnschnall22 » Sun Jun 06, 2021 6:17 am
LeonardL
Re: isolator
Post by LeonardL » Sun Jun 06, 2021 7:05 am
First of all you need to contact Lavoy the owner of this site. He can probably fix you up with what you need. To answer your question... Yes I have had the linings replaced by a clutch / brake relining company. I went to my local NAPA store and they sent the isolators off for me. The lining is held on in the same process as common bonded brake linings. This was several years ago and I know off at least two machines that are still running with these relined isolators in them. Hope this helps and good luck.
cantbeatadeere
Re: isolator
Post by cantbeatadeere » Tue Jun 15, 2021 6:01 pm
I have not been on here in a while....Lavoy helped me put together a package that converted a B or C into a D isolator....my 350C now has a D style isolator in it...AWSOME and bullet proof, love it. last I new he was going to assemble a kit with the parts needed to do this??????????
1970- JD 2520, 1991- JD 400G long track, 2003- JD 4710, 2012- JD 1026R, 2014 Bobcat E42 long arm, 2016- 14ft dump trailer, 2017- 24ft 11,000lb hyd. tilt equipment trailer aaand 2018 ram 2500 Big Horn CUMMINS :D :D
Re: isolator
Post by Lavoy » Wed Jun 16, 2021 9:07 am
I can still build isolators, but I am out of flywheels. If you can source a used flywheel, not a problem.
cantbeatadeere
Re: isolator
Post by cantbeatadeere » Wed Jun 23, 2021 7:37 pm
If you do not go the "D" isolator way......I have everything out of my 350 c flywheel, isolator and new springs all in great shape. may let them go ...where are you located??
Users browsing this forum: No registered users and 294 guests
