The next victim part II
Post by Lavoy » Wed May 30, 2007 8:10 am
I think it is like 3 3/8", it is a common dimension, should bolt right in your 2010. There are different gear ratios, don't know how to tell what you would need though. I spun a factory two cylinder tach with a drill, and then spun this one, and they read the same. I had another NOS tach out of a semi that I put in one crawler, but it read 200 RPM slow, so it was a different ratio.
dlplost
Post by dlplost » Wed May 30, 2007 10:20 am
Good question Stretch, I was just going to ask the same.
I've got a 2010 Diesel Crawler needing a new Tach.
So how about it Lavoy? They got a Tach that will work on the 2010?
dlplost
Post by dlplost » Wed May 30, 2007 10:23 am
Oh yea, we'd have to look at direction of rotation also.
Just checked with JD and the original AT17449T Tach is not available.
So, I guess we need an original 2010 tach (working) to compare to.
Any volenteers out there?
Post by Lavoy » Wed May 30, 2007 9:42 pm
I ran the crawler a little bit today, to see how the tach worked. I checked it against my phototach, and it is dead on the money. If rotation and gear ratio are the same, there should be no reason this would not work in a 1010 or 2010 as well.
Post by Lavoy » Sun Jun 10, 2007 9:46 pm
Okay, here is a recent pic, track frames installed, and the engine runs. Tested everything for function and then took it out of the stand. Right now it is sitting on the floor waiting for the dyno to get rolled in tomorrow.
Post by Lavoy » Fri Jul 06, 2007 9:39 pm
A little more recent pic, on it's wheels, and moving under it's own power in this pic. Loader has been installed since this pic, will post more later.
Post by wwattson » Fri Jul 06, 2007 10:06 pm
Nice job Lavoy! You really do nice work.
sbarr
Post by sbarr » Sun Jul 08, 2007 12:07 pm
Looks great,just a quick question where is the pump for the loader on it,mine is on the end of the crank and had to modify the nose for it to fit,Henry loader though,but I'm use it is the factory setup.
58 420c w 61 blade and 3pth and pto,57 420c w loader,48 D,48 M,Allis D-15 and a Super Duty to haul these!!!!
Post by Lavoy » Wed Jul 11, 2007 5:47 pm
The pump is in the same basic location as yours, but is a factory mounting and different grille so it all fits.
jdjoe_indiana
Looks GREAT
Post by jdjoe_indiana » Wed Jul 11, 2007 9:51 pm
Very nice job. I am so jealous looking out the window at my rusty "prize", waiting to get redone. If you don't mind me asking how much do you have invested in this restoration? I am more interested in parts and supplies and not counting your labor. I want to know how to budget. I know you indicated that getting tracks reworked is close to $1000. What do the new rollers cost? If you would rather not post, could you PM me. Again terrific work! Thanks Joe
Joe Hartman - JD 420C 5 roller, 4spd, reverser. Henery Loader and Backhoe
44 JD B
51 JD MT
52 JD MT
58 JD 730 D RC
39 JD H
86 JD 420 GT
65 JD 110 RF
2002 Dodge Cummins
Post by Lavoy » Thu Jul 12, 2007 10:02 am
It can really vary depending on how good the crawler you start with is. A rough guess on a loader crawler is going to be $6000 and up as far as parts. Add in some bad undercarriage, bad drivetrain, or some other large components, and you can add another few thousand in a hurry. Even doing a lot of the work yourself, you still can get a thousand dollars in painting and sandblasting.
Keep in mind, that this is assuming a ground up restoration starting from an empty transmission case, and building a crawler from there with all components rebuilt.
New rollers are all over the scale. I am trying to develop another source for them as we speak, but $130-$150 apiece for new sealed lifetime rollers is going to cover most brands. Most likely they will have 9/16" bolt holes instead of 1/2", but that is not a really big problem.
Post by Lavoy » Thu Jul 12, 2007 6:46 pm
Here is a pic with the loader and scarifier installed. Sorry I have been slow getting pics up, but not enough hours in the day.
hunter41mag
Post by hunter41mag » Wed Aug 15, 2007 2:28 pm
Looking better then new, nice work. Now all you need to do is get rid of the heat and test it in 12 plus inches of snow!!!!
Don
Eastern PA
440IC (1960)
Post by Lavoy » Sun Oct 07, 2007 5:15 pm
Here is a final pic with the decals installed.
Finished JD 420 IC
Post by JD440ICD2006 » Sun Oct 07, 2007 8:26 pm
Looks great! Have fun.
Chuck W.
