The next victim part II
I think it is like 3 3/8", it is a common dimension, should bolt right in your 2010. There are different gear ratios, don't know how to tell what you would need though. I spun a factory two cylinder tach with a drill, and then spun this one, and they read the same. I had another NOS tach out of a semi that I put in one crawler, but it read 200 RPM slow, so it was a different ratio.
Looks great,just a quick question where is the pump for the loader on it,mine is on the end of the crank and had to modify the nose for it to fit,Henry loader though,but I'm use it is the factory setup.
58 420c w 61 blade and 3pth and pto,57 420c w loader,48 D,48 M,Allis D-15 and a Super Duty to haul these!!!!
- jdjoe_indiana
Looks GREAT
Very nice job. I am so jealous looking out the window at my rusty "prize", waiting to get redone. If you don't mind me asking how much do you have invested in this restoration? I am more interested in parts and supplies and not counting your labor. I want to know how to budget. I know you indicated that getting tracks reworked is close to $1000. What do the new rollers cost? If you would rather not post, could you PM me. Again terrific work! Thanks Joe
Joe Hartman - JD 420C 5 roller, 4spd, reverser. Henery Loader and Backhoe
44 JD B
51 JD MT
52 JD MT
58 JD 730 D RC
39 JD H
86 JD 420 GT
65 JD 110 RF
2002 Dodge Cummins
44 JD B
51 JD MT
52 JD MT
58 JD 730 D RC
39 JD H
86 JD 420 GT
65 JD 110 RF
2002 Dodge Cummins
It can really vary depending on how good the crawler you start with is. A rough guess on a loader crawler is going to be $6000 and up as far as parts. Add in some bad undercarriage, bad drivetrain, or some other large components, and you can add another few thousand in a hurry. Even doing a lot of the work yourself, you still can get a thousand dollars in painting and sandblasting.
Keep in mind, that this is assuming a ground up restoration starting from an empty transmission case, and building a crawler from there with all components rebuilt.
New rollers are all over the scale. I am trying to develop another source for them as we speak, but $130-$150 apiece for new sealed lifetime rollers is going to cover most brands. Most likely they will have 9/16" bolt holes instead of 1/2", but that is not a really big problem.
- hunter41mag
- JD440ICD2006
Finished JD 420 IC
Looks great! Have fun.
Chuck W.
Chuck W.
Users browsing this forum: No registered users and 165 guests
