Straight 350 track frame
What are your thoughts on cutting the back of the track frame off to remove and replace the final drive?
Re: Straight 350 track frame
Use this link and read the info in that post and the links in it as well. viewtopic.php?t=9530
Lazy mans way, absolutely no need to cut the track frame.
Where do you plan to put your sprocket shield and rock guard if the track frame is cut?
Used a similar method to remove it but this technique appears to be more graceful. Thank you everyone
Users browsing this forum: Bing [Bot] and 28 guests
