Straight 350 track frame
Blane
Post by Blane » Thu Nov 26, 2020 12:51 pm
What are your thoughts on cutting the back of the track frame off to remove and replace the final drive?
Re: Straight 350 track frame
Post by Jim B » Thu Nov 26, 2020 5:17 pm
Use this link and read the info in that post and the links in it as well. viewtopic.php?t=9530
Post by Lavoy » Thu Nov 26, 2020 6:16 pm
Lazy mans way, absolutely no need to cut the track frame.
CatD8RII
Post by CatD8RII » Thu Nov 26, 2020 7:35 pm
Where do you plan to put your sprocket shield and rock guard if the track frame is cut?
Blane
Post by Blane » Thu Nov 26, 2020 7:46 pm
Used a similar method to remove it but this technique appears to be more graceful. Thank you everyone
Users browsing this forum: Google [Bot] and 25 guests
