JD 350 PARTS
TB350
JD 350 PARTS
Post by TB350 » Wed Sep 10, 2014 7:35 am
LOOKING FOR SHIFTER BOOT AND AIR FILTER BOWL FOR MY JD 350
Post by Lavoy » Wed Sep 10, 2014 8:32 am
Shift boot is Deere only, probably filter bowl too unless you are talking about pre-cleaner.
TB350
Post by TB350 » Wed Sep 10, 2014 10:34 am
ANY IDEA WHERE TO GET THEM?
Post by Lavoy » Wed Sep 10, 2014 10:38 am
Any Deere dealer should be able to order them for you. If you have no dealer near you, let me know, I can get them.
jthornton
Post by jthornton » Wed Sep 10, 2014 4:08 pm
If your talking about the pre-cleaner I just ordered one online from apartsdepot.com Donaldson H001250
JT
TB350
Post by TB350 » Tue Sep 23, 2014 11:12 am
FOUND A MANIFOLD!!!! NOW ANY TIPS ON CHANGING THE FAN BELT?
alanpeters257
Post by alanpeters257 » Tue Sep 23, 2014 2:04 pm
I supported the nose, unbolted it, and slide it forward several inches. I then removed the two bolts holding the hydraulic pump. I was then able to get enough space between the split coupling on the hydraulic pump shaft to slide the new belt through. Then I simply routed it over the correct pulleys and put everything back together. It took about an hour max.
TB350
Post by TB350 » Tue Sep 23, 2014 2:12 pm
GREAT, THAT'S WANT I WAS HOPING TO DO, I HAVE MY NOSE COMPLETLY OFF SO IT SHOULD BE FAIRLY EASY.
THANKS,
BY THE WAY GOT SENT THE WRONG MANIFOLD, ANY IDEAS ON WHERE TO FIND ONE.
TB350
Post by TB350 » Tue Sep 23, 2014 2:42 pm
here's a picture of what i have.
http://i.imgur.com/CNBPtuo.jpg
Post by jtrichard » Tue Sep 23, 2014 3:25 pm
2 things #1 what is wrong with your manifold? in the pics it don't look bad ..... #2 a little internet etiquette....... take your cap locks OFF on blogs all caps is considered YELLING... :) :)
TB350
Post by TB350 » Tue Sep 23, 2014 3:28 pm
the picture is of one i was sent, it's the wrong one. just thought someone might could use it. mine has some cracks in it.
flytripper
Post by flytripper » Thu Oct 23, 2014 10:44 am
I was able to source a manifold from these guys...
https://www.facebook.com/DenglerTractor
They seemed to have used parts for a lot of stuff.
