JD 350 PARTS
JD 350 PARTS
LOOKING FOR SHIFTER BOOT AND AIR FILTER BOWL FOR MY JD 350
Shift boot is Deere only, probably filter bowl too unless you are talking about pre-cleaner.
Any Deere dealer should be able to order them for you. If you have no dealer near you, let me know, I can get them.
alanpeters257
I supported the nose, unbolted it, and slide it forward several inches. I then removed the two bolts holding the hydraulic pump. I was then able to get enough space between the split coupling on the hydraulic pump shaft to slide the new belt through. Then I simply routed it over the correct pulleys and put everything back together. It took about an hour max.
2 things #1 what is wrong with your manifold? in the pics it don't look bad ..... #2 a little internet etiquette....... take your cap locks OFF on blogs all caps is considered YELLING...
flytripper
I was able to source a manifold from these guys...
https://www.facebook.com/DenglerTractor
They seemed to have used parts for a lot of stuff.
