440 icd track adjusting
gerrell
Post by gerrell » Thu Mar 07, 2013 3:12 pm
How do tighting the tracks on 440 icd loader dozer
gregjo1948
440icd track adjusting
Post by gregjo1948 » Fri Mar 08, 2013 6:58 am
I think on a 440 loader it will have hydraulic adjusters. Right behind your front idler, there is a special grease fitting that you pump grease into to push the idler ahead, tightning the track. You need a special tip for your grease gun to utilize the fitting on the adjuster. I think you can remove that fitting and install a regular fitting to do the adjusting. gregjo1948
whiteclipse16
Post by whiteclipse16 » Fri Mar 08, 2013 7:15 am
greg is correct.
However you may have the non-hydraulic adjuster. This means you have a large nut and stuff that you have to get loose and crank to adjust.
Ben
gregjo1948
Post by gregjo1948 » Fri Mar 08, 2013 6:13 pm
Ben-- I thought the threaded shaft adjusters were on the 4 roller machines and if it's a loader, it probably is a 5 roller. I MIGHT BE WRONG! :shock: gregjo1948
Post by Lavoy » Sat Mar 09, 2013 11:03 am
Hyd adjusters were an option, mechanical were standard.
No 4 roller 440's.
gregjo1948
Post by gregjo1948 » Sat Mar 09, 2013 8:16 pm
Thanks Lavoy-- Didn't know there weren't any 4 roller 440's. I talked to guy today that said he has a 4 roller 1010, and it has the mechanical tensioners. Didn't know they made 4 roller 1010's and that they still used the threaded tensioners on the 1010's. I guess I had a good day: I learned stuff. :o gregjo1948
DukeofDeere
Post by DukeofDeere » Sat Mar 09, 2013 8:27 pm
My neighbor has a 4 roller 440IC.
Friend in Minnesota has one too.
Duke
Post by jtrichard » Sat Mar 09, 2013 9:45 pm
they still used threaded tensioners on 2010 also but not very many i have only seen 2 or 3... on the 4 roller 1010 they did not use upper idler
gerrell
Post by gerrell » Sat Mar 09, 2013 9:48 pm
Thanks y'all I got it done
Post by jtrichard » Sat Mar 09, 2013 10:22 pm
did you have threaded or hyd. adjusters?
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Sun Mar 10, 2013 7:57 am
I under stand that Deere ended the 4 roller track frame with the 430 model and I would like to see pictures of later models that are 4 roller for my research. I cant imagine Deere having the option of down grading their track frame for their industrials?
nothing crawles like a deere
Post by jtrichard » Sun Mar 10, 2013 3:11 pm
look at 1010 parts book shows some had 4 roller and no upper idler and track was 32 link... 36 link on 5 roller model.... 350 also used both 4 and 5 roller as per parts book also it appears the 4 roller did not have upper idler and was 32 link and 36 link
gerrell
Post by gerrell » Mon Mar 11, 2013 12:30 am
It was threaded. It had a cover over the spring in the back that I couldn't get off so I didn't kno if it was hydro or not
Post by jtrichard » Mon Mar 11, 2013 12:48 am
the hyd. adjuster goes in place of the threaded
gregjo1948
Post by gregjo1948 » Mon Mar 11, 2013 6:18 am
Will the threaded adjuster off a 1010 work on a 440 with hydraulic adjusters? gregjo1948
