440 icd track adjusting
How do tighting the tracks on 440 icd loader dozer
440icd track adjusting
I think on a 440 loader it will have hydraulic adjusters. Right behind your front idler, there is a special grease fitting that you pump grease into to push the idler ahead, tightning the track. You need a special tip for your grease gun to utilize the fitting on the adjuster. I think you can remove that fitting and install a regular fitting to do the adjusting. gregjo1948
whiteclipse16
Ben-- I thought the threaded shaft adjusters were on the 4 roller machines and if it's a loader, it probably is a 5 roller. I MIGHT BE WRONG!
gregjo1948
Hyd adjusters were an option, mechanical were standard.
No 4 roller 440's.
No 4 roller 440's.
Thanks Lavoy-- Didn't know there weren't any 4 roller 440's. I talked to guy today that said he has a 4 roller 1010, and it has the mechanical tensioners. Didn't know they made 4 roller 1010's and that they still used the threaded tensioners on the 1010's. I guess I had a good day: I learned stuff.
gregjo1948
- DukeofDeere
they still used threaded tensioners on 2010 also but not very many i have only seen 2 or 3... on the 4 roller 1010 they did not use upper idler
- mapaduke@yahoo.com
look at 1010 parts book shows some had 4 roller and no upper idler and track was 32 link... 36 link on 5 roller model.... 350 also used both 4 and 5 roller as per parts book also it appears the 4 roller did not have upper idler and was 32 link and 36 link
Will the threaded adjuster off a 1010 work on a 440 with hydraulic adjusters? gregjo1948
Users browsing this forum: No registered users and 57 guests
