kedorland
Post
by kedorland » Wed Aug 15, 2012 9:36 pm
Ran our 450C out of fuel today.....crap. It runs so lean (on fuel) along with being so nice out. Was killing a few hrs clearing ground I lost track of time.
Well on the up-side.....I'll know the fuel delivery system better....
Kevin from Iowa.
1975 450C. 1977 450CA loader, with winch and log arch. Is true..tracked equipment is addicting.
Willyr
Post
by Willyr » Wed Aug 15, 2012 11:02 pm
Your going to have to bleed those injectors to get it to start again.
kedorland
Post
by kedorland » Wed Aug 15, 2012 11:51 pm
Thank you. I'm still mechanically green on this machine. It is a loader machine...no doubt dead.....with side engine shields.
Grateful it is sitting to where I can drive up to it. The fuel system sputtered...I reached to kill the engine....no doubt it went on another 5 to 10 revolutions. Should be a lot of air in the fuel lines?
Should prove to be interesting.
Kevin from Iowa.
hydrogeo
Post
by hydrogeo » Thu Aug 16, 2012 10:37 am
I am not familiar with the JD diesels, but I had an old IH crawler that there was no way to bleed all the air from the filter housings unless a bit of air pressure was applied to the fuel tank.
Willyr
Post
by Willyr » Mon Aug 20, 2012 6:44 pm
You loosen the fuel fitting at the injector.
kedorland
Post
by kedorland » Wed Aug 22, 2012 10:41 pm
Most of the air purged......a couple of self created leaks (post injector pump) to fix and should be up and puttering again.
Kevin from Iowa.
Users browsing this forum: Google Adsense [Bot] and 156 guests
