What kind of dozer do I have
getawaystix
Post by getawaystix » Mon Jul 23, 2012 8:53 am
Hey guys.....need some help here.
Have this dozer in the barn and I need some info on it.
The serial/model # is
SNT 5F3M 0291 54T
All help appreciated......Linda
Post by Lavoy » Mon Jul 23, 2012 5:58 pm
Not enough digits I don't think. A pic would be big help, but how many cylinder engine, that might narrow it down fast.
LeonardL
Post by LeonardL » Tue Jul 24, 2012 8:17 am
Where did you find this number? On the engine? Or on the machine itself? Lavoy is right... There aren't enough numbers.
getawaystix
Post by getawaystix » Tue Jul 24, 2012 12:36 pm
The numbers posted first were on a small plate ( 1 1/2 "x 4" ) taken off the dozer
Found these numbers on the left side.. maybe these help..
T20707T-L
Have pictures as well....will be uploading them
Tell me to find any other numbers..the engine is coverd by plates that can be taken off
KenP
Post by KenP » Tue Jul 24, 2012 12:57 pm
deleted
getawaystix
Post by getawaystix » Tue Jul 24, 2012 3:46 pm
Talked to my son.... he said it is a 440 2 cylinder Detroit deisel
getawaystix
Post by getawaystix » Wed Jul 25, 2012 2:28 pm
CatD8RII
Post by CatD8RII » Wed Jul 25, 2012 4:28 pm
That's a 450 (the battery box is either an early B or a straight 450). And after what Ken has said, I'd be inclined to agree with him that its a straight 450
LeonardL
Post by LeonardL » Wed Jul 25, 2012 6:54 pm
I agree with these guys that it is definitely a 450. Looks pretty sweet too!!
JWB Contracting
Straight 450
Post by JWB Contracting » Wed Jul 25, 2012 7:27 pm
Its a straight 450, the HLR shifter is floor mounted. Does look nice and straight.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
getawaystix
Post by getawaystix » Thu Jul 26, 2012 5:28 am
Thanks for all the info guys..
Really glad the pictures could help give some info on it....
Still am not sure of the year....was told around 1958-1960...
My son got it out last spring......ran well
I just put the charger on it ..and it started right up..
I belive my dad may have made the top for it...not sure..he could weld..and it has definitley been welded together
Linda......USMCMOM
Post by Tigerhaze » Thu Jul 26, 2012 8:20 am
getawaystix wrote: Still am not sure of the year....was told around 1958-1960...
That would have been true if it were a 440 but it is a 450. 1965 was the first year for straight 450s and as KenP said based on your serial number it is likely a 1966.
http://www.jdcrawlers.com/messageboard/ ... php?t=2415
FYI, the serial number range is more important than the year manufactured when you order parts so no worries about getting the year of manufacture exact.
BTW, thank your son for his service to our country.
getawaystix
Post by getawaystix » Fri Jul 27, 2012 2:33 pm
Tigerhaze.....
Will always tell my son that someone has thanked him for his service...thanks for noticing
Another question about this dozer...Are parts hard to find this type?
We tried to sell it last spring and were told that parts would be hard to find and take too long to get. It was neighbor farmers who were interested...
They thought the year for this dozer at that time was 1958 to 1960...
Linda..USMCMOM
Post by Tigerhaze » Fri Jul 27, 2012 3:36 pm
I think the people that said parts are hard to find and take too long to get are exaggerating a little bit. Parts for 450s are generally easier to find than for earlier crawlers. Again, they may have been thinking it was a 440.
The availability of parts will depend ultimately on which parts you need- many are still available from John Deere directly as well as aftermarket suppliers. Service items such as filters can be found from a variety of tractor supply sources. Some items such as diesel injection pumps are common to other brands of machines so parts can be had from a variety of diesel suppliers.
Lavoy, the board administrator, is one of the first sources to check with for JD crawler parts- he will steer you in the right direction even if he doesn't carry it.
If Lavoy is not available, a quick way to determine whether a part is readily available is to log onto John Deere's parts website and serach for what you need:
You will need to do a model search for 450 and then select "922 - 450 Crawler Tractor - 08Nov06". If you put parts that you want to know about in your cart, it will tell you whether they are available and the list price or if they are "no longer available". You will need to be logged in to see prices.
If parts are no longer available from Deere, there is still a chance that Lavoy can find them for you or they can be obtained from a salvage yard or other aftermarket source. There are a lot of 450s out there. Also some parts can be repaired.
Users browsing this forum: No registered users and 380 guests
