idler question
JD430C
idler question
Post by JD430C » Fri May 12, 2006 8:29 pm
i have a friend who has a 420 with a bad front idler. i have a NOS 1010 idler. will the brackets off the 420 idler bolt onto the 1010 idler? thanks
andrew
Post by Lavoy » Fri May 12, 2006 10:09 pm
No, 1010 uses quite a bit bigger axle than a 420, and also uses bigger seals and thrust plates.
JD430C
Post by JD430C » Sat May 13, 2006 9:59 am
thanks lavoy. they looked close, but i didnt want to take them apart till i found out if they would or not. thanks
andrew
Users browsing this forum: No registered users and 225 guests
