440 i crawler loader manual
wolf run shoals
Post by wolf run shoals » Tue Apr 13, 2010 6:07 am
Which manual do I want in order to service my new to me loader? I have not seen a service manual listed on ebay, just parts. Is the 440 motor the same as the one on a deer tractor?
Steve
Post by Stan Disbrow » Tue Apr 13, 2010 8:53 am
If it's the gas engine, then it's pretty much the same as on the 420 and 430 series wheel tractors. The diesel was only used in the 440 series and the 435 ag wheel tractor.
I don't know about the 440 service manual. It may be that since the 440 was specific for the industrial market, they put everything into one manual and didn't make one flip through all those older agricultural model manuals.
For the ag line, one has to have a set of service manuals. Each manual covers only the differences between models. They figured only service shops needed manuals, so they made each as thin as possible by not covering something found in an earlier manual.
For example, things that remained the same on the 420 as they were on the 40 are found in the 40 manual, not the 420 one.
Also, things that remained the same on the 420 as they were on the M are found in the M manual, not the 40 or the 420 ones.
I also need the 430 manual as my 420c is a Phase-III with differential-style reverser, and that is not covered in the 420 manual but in the 430 one!
So, for my 420 I have to have five manuals, four shop (M, 40, 420 and 430) and one parts. Fortunately, the parts manual is the latest edition, so it covers the entire line from the M thru the 440 and all I have to do is figure out which variant of a particular part I need.
Now, what I do not know is if the 440 manual follows this pattern or not. I've always used the manuals I have to work on a 440. Heck, once you're used to these things, the 440 isn't really any different so I never needed a 440 specific manual.
Hopefully, the 440 is all in one manual and you won't need the set.
later!
Post by Lavoy » Tue Apr 13, 2010 9:05 am
You need SM2023 srvice manual for 440 series gas.
lavoy
wolf run shoals
440 manual
Post by wolf run shoals » Tue Apr 13, 2010 9:38 am
Fortunately I have the 420 manual as i have a 420 tractor. The carberator is a little different and I really haven't looked at much else. I'll have to find the service manual Lavoy mentions as I know nothing about this thing.
Lavoy, any word on Track guides?
Steve
PS I really appreciate this site!
Post by Lavoy » Tue Apr 13, 2010 1:49 pm
Not sure what you mean by track guides, do you have part number?
wolf run shoals
rail links
Post by wolf run shoals » Tue Apr 13, 2010 2:35 pm
Sorry, I meant rail links.
Steve
Post by Lavoy » Tue Apr 13, 2010 3:16 pm
I am pretty much out of used individual links, might be able to put toghether one more set of complete rails if I can scrounge enough pins and bushings.
Post by Stan Disbrow » Tue Apr 13, 2010 3:44 pm
Just to educate me, is the 440 manual self-contained or does one need the stack of older manuals like one does with the ag machines?
Also, if it's self-contained, is the number you posted just for crawlers, or are the various wheel 440s in there as well?
later!
Post by Lavoy » Tue Apr 13, 2010 4:52 pm
The one I posted is the 440 gas manual, covers wheel and crawler. Like the later manuals, I think it is short on some of the engine stuff and you reference the 40 manual. Diesel is different, as well as an attachment like the loader would be it's own manual.
shinnery
Post by shinnery » Tue Apr 13, 2010 11:08 pm
The main manuals for 440IC(D) are
SM-2023 John Deere 440 series spark ignition tractors
SM-2028 General Motors 2-53 series diesel engine for John Deere tractors
PC-573 Tractor - "440IC" Industrial Crawler
PC-609 Tractor- "440ICD" Industrial Crawler Diesel
The 440I tractors have separate parts lists and I have a 831 loader parts list somewhere, I will find it and get that number also.
In the SM-2023 it has about 36 pages on the engine so it MAY be stand alone. They mention two engines, Were there ever any "tractor fuel" engines put in a crawler?
:P
Post by Lavoy » Wed Apr 14, 2010 8:33 am
Yes, I had an "all-fuel" 420 crawler for a couple years.
Users browsing this forum: No registered users and 294 guests
