350B brake drum
350B brake drum
How do you know when the brake drum is worn too much and needs replacing?
JD 350B w/ 4 in1
JD 1025R Sub Compact
CAT 259D3 high flow with Mastodon mulcher head; CAT BRX 318 bush hog
Cat 304 Mini Ex with Bushmaster Brush Cutter and 28" Torrent mulcher
Soilmover Dirt Pan
Soilmover Dirt Pan
Unless you have a fairly noticeable groove in it, I wouldn't worry about it. If need be, I can have a set of bands made with thicker lining, and you can turn your drums.
350b brake drum
I measured the depth of wear and it is .035 of wear. Is that to much ?
Bennett
Bennett
JD 350B w/ 4 in1
Soilmover Dirt Pan
Soilmover Dirt Pan
To me, with standard brake bands, I think you should be fine. There should be that much adjustment, although I suppose over the life of the bands, you will lose some hours because you may not be able to tighten them down all the way when worn.
