350B brake drum
cjman1977
350B brake drum
Post by cjman1977 » Wed Jan 07, 2015 10:00 am
How do you know when the brake drum is worn too much and needs replacing?
JD 350B w/ 4 in1
JD 4520 Compact Utility
JD 1025R Sub Compact
Cat 303.5 Mini Ex with Bushmaster Brush Cutter
Soilmover Dirt Pan
Post by Lavoy » Wed Jan 07, 2015 10:16 am
Unless you have a fairly noticeable groove in it, I wouldn't worry about it. If need be, I can have a set of bands made with thicker lining, and you can turn your drums.
cjman1977
350b brake drum
Post by cjman1977 » Wed Feb 11, 2015 9:22 am
I measured the depth of wear and it is .035 of wear. Is that to much ?
Bennett
JD 350B w/ 4 in1
Soilmover Dirt Pan
Post by Lavoy » Wed Feb 11, 2015 10:33 am
To me, with standard brake bands, I think you should be fine. There should be that much adjustment, although I suppose over the life of the bands, you will lose some hours because you may not be able to tighten them down all the way when worn.
