John Deere 350B with backhoe
airtwist
Post by airtwist » Sat Jan 03, 2015 12:14 pm
I really enjoy this site and appreciate everyone taking the time to share their knowledge. I have been reading on here for some time and have got the "cheap crawler fever". Looking at John Deere 350B with 4 in 1 bucket with backhoe..1970 model. Has been sitting for 10 plus years out in the weather..Any bits of wisdom that can be shared would be greatly appreciated..The owner is asking $2,500.
http://i166.photobucket.com/albums/u92/ ... 369cf5.jpg[/url]
Robert
rdw
original possum
Post by original possum » Sat Jan 03, 2015 1:24 pm
Worth nearly that much at scrap yard. If the engine is not stuck and holds water and oil (separately) it is worth it. Of course, that assumes your labor will be free.
notmeu
Post by notmeu » Sat Jan 03, 2015 3:18 pm
Even if it needed some work and had to pay someone, your still way ahead of the game! That's a good price...
Post by Lavoy » Sat Jan 03, 2015 3:47 pm
You are likely looking at a lot of work ahead of you, but at that price, with that undercarriage, you really can't lose.
cjman1977
350b
Post by cjman1977 » Sat Jan 03, 2015 4:30 pm
I wish I had that machine. I am in NC near Raleigh. I have A 350B and am doing a partial rebuild on the undercarriage due to problems found while putting steering clutches in. Figured might as well do it now while its apart. If you need some help, Private message me. Machine looks rough but the undercarriage is excellent. If you dont buy it let me know.
JD 350B w/ 4 in1
JD 1025R Sub Compact
CAT 259D3 high flow with Mastodon mulcher head; CAT BRX 318 bush hog
Cat 304 Mini Ex with Bushmaster Brush Cutter and 28" Torrent mulcher
Soilmover Dirt Pan
Post by jtrichard » Sat Jan 03, 2015 5:15 pm
If it runs and moves (dont care if it turns) it should already be in your yard ......the undercarriage alone is worth the 2500 ........ the rest is free :o :o
Post by Paul Buhler » Sun Jan 04, 2015 8:31 am
How mechanically inclined are you? Was the exhaust pipe covered? The engine and the steering clutches may be stuck. Both can be repaired, but will take time and money. As others have said, the base machine is worth the asking price if you want a project. Here's to a potentially satisfying revival.
airtwist
Post by airtwist » Sun Jan 04, 2015 8:02 pm
Paul Buhler wrote:How mechanically inclined are you? Was the exhaust pipe covered? The engine and the steering clutches may be stuck. Both can be repaired, but will take time and money. As others have said, the base machine is worth the asking price if you want a project. Here's to a potentially satisfying revival.
I consider myself mechanically inclined although I am new to crawlers with my experience to this point being tractor related (1959 Fordson Dexta and 1956 John Deere 430 gas). Good point about checking the exhaust pipe as I neglected to check that and I already assumed that the steering clutches would be a problem based on prior posts that I have read..I am fortunate that I am currently working on site where the crawler is located and can continue to keep an eye on it before making the leap. Thanks again everyone for the great input and I'll post more updates as I mull taking the plunge on the "cheap crawler". I certainly have the fever. I have a hard time focusing on work and keep wanting to go over and lift the hood and get busy.
rdw
Post by Paul Buhler » Mon Jan 05, 2015 9:25 am
I'm sure that there are people on this board that will have had experience bringing a diesel 350 engine back to life successfully who would be willing to share some things to look out for. The injection pumps (fairly expensive)have close tolerances and one that's full of old fuel and possibly water may have to be handled carefully. I'm outside my element now (dead diesels) so can't help much. I noticed that the air cleaner is missing too which means that some dirt or critters may have gotten into places that are meant to be clean. Good luck. Paul
Scottyb
Post by Scottyb » Mon Jan 05, 2015 11:00 pm
Take the head off and inspect, clean and then see if you can turn it over a little at a time to allow you to clean, scrape or sand the ridges and rust or whatever you find, off the cylinder walls. The pistons could pop out a sleeve on the way up, so be sure to use a bar or... something bolted down with a couple of head bolts to keep them in place ! I started one after the same long time and the cylinders were full of seeds that mice put there... including a muffler full. As well, the 350b has a hydraulic pump disconnect. Might be a good Idea to use this for the initial start up if it is not seized from lack of use. It is the small lever ,bottom right at the front/ side of the engine just forward of the dip stick. (This disconnect is used to change a fan belt without removing the pump to get around the main pulley). As well, the hydraulic lines for the hoe must be hooked up to the hoe or to each other as the fluid in the system runs continuously when the pump is engaged and engine running.
backhoe attachment.
Users browsing this forum: No registered users and 69 guests
