ok I removed these clips to adjust the clutch and now they cant go back on because there isn't enough space between the bolt head and lock nut. what am I doing wrong.
Roy
straight 350 steering clutch pressure plate return clip.
Throw them in the garbage, then you have plenty of clearance.
350 return clips
Ha, I like Lavoys' reply... get er done.
You mean the clips that exist only so the factory line can run at a faster pace?
Yes, didn't catch that, the gap should be bigger. You were adjusting the levers down (closer to the pressure plate frame) correct?
Users browsing this forum: No registered users and 330 guests
