straight 350 steering clutch pressure plate return clip.
joshuaz2
Post by joshuaz2 » Tue Aug 19, 2014 12:44 pm
ok I removed these clips to adjust the clutch and now they cant go back on because there isn't enough space between the bolt head and lock nut. what am I doing wrong.
Roy
Post by Lavoy » Tue Aug 19, 2014 1:40 pm
Throw them in the garbage, then you have plenty of clearance. :lol:
Post by jtrichard » Tue Aug 19, 2014 6:53 pm
did you put new clutches in? if you are adjusting for wear the gap would get bigger not smaller :? :?
pondhogvt
350 return clips
Post by pondhogvt » Tue Aug 19, 2014 7:41 pm
Ha, I like Lavoys' reply... get er done.
Post by Stan Disbrow » Wed Aug 20, 2014 5:40 am
You mean the clips that exist only so the factory line can run at a faster pace? ;)
Post by Lavoy » Wed Aug 20, 2014 8:14 am
Yes, didn't catch that, the gap should be bigger. You were adjusting the levers down (closer to the pressure plate frame) correct?
joshuaz2
Post by joshuaz2 » Thu Aug 21, 2014 4:48 pm
I am adjusting a new clutch and plate. when I get it adjusted with the tool the gap isn't big enough to get the clips back in. I ended up just grinding a little off the clips and pounding them in.
Users browsing this forum: No registered users and 414 guests
