JD1010 Crawler Diesel Starter 9 or 10 tooth
TunkCreek
Post by TunkCreek » Tue Nov 19, 2013 10:02 am
In trying to find a starter for my 1010, the part #s 1107573 ( what I pulled out) and the replacement # AT17411T both list a 9 or 10 tooth drive gear depending on where you look. The actual one removed (1107573) has 10 teeth. Don't know if this was a replacement or not. Dumb question - should I match the 10 tooth starter I pulled out or could it be wrong. I have no gear grinding. Would a 9 tooth work? Take it easy on this newby (':shock:')
DukeofDeere
Post by DukeofDeere » Tue Nov 19, 2013 6:35 pm
Gas is 10
Diesel is 9
Duke
DukeofDeere
Post by DukeofDeere » Tue Nov 19, 2013 6:38 pm
Welcome to the site!
We are all learning as we go.
Some with a few more scars than others.
If the machine can sit for a while I would rebuild the starter you have.
Happy wrenching,
Duke
gregjo1948
Post by gregjo1948 » Wed Nov 20, 2013 6:08 am
I think some of the diesel starters were 24 volt also. gregjo1948
Post by Tigerhaze » Wed Nov 20, 2013 10:06 am
I believe the 1010s like the 2010s were originally configured to be 12V positive ground, although that would not have stopped someone from converting to 24V.
Post by Lavoy » Wed Nov 20, 2013 3:33 pm
24 volt was an option, I have never seen one still in that configuration though.
Post by jtrichard » Thu Nov 21, 2013 2:37 pm
Lavoy is right 1010 was available in 24 volt.... tiger is right that 2010 was 12 volt only and pos ground
Post by Lavoy » Thu Nov 21, 2013 5:28 pm
Good catch, I should have said 1010, sorry.
Post by jtrichard » Thu Nov 21, 2013 7:18 pm
tunk i just noticed you did not say if yours is gas or diesel?? they take totally different starters
shinnery
Post by shinnery » Fri Nov 22, 2013 12:49 am
Wal, down here in Texas the way I read the link title it says diesel!
DukeofDeere
Post by DukeofDeere » Fri Nov 22, 2013 7:07 am
Yep..
I recon up here in Michigan it says diesel too!
Just sayin.
Duke
Post by Stan Disbrow » Fri Nov 22, 2013 7:39 am
Down in South America it says Gasoil.... :lol:
Post by jtrichard » Fri Nov 22, 2013 11:57 am
HA HA guys i did not double check the heading OOPS :oops:
TunkCreek
Post by TunkCreek » Fri Nov 22, 2013 7:47 pm
Thanks Duke. That's my plan to get it rebuilt. Hopefully before the snow flies and makes it that much more fun on the install. Thanks again for the info.
Post by jtrichard » Fri Nov 22, 2013 8:19 pm
before you sent it out for REBUILD you should make sure you have a diesel starter a gas starter will fit the diesel i have seen a few diesels with gas starters on them... seen one on ebay told the guy it was a gas he said it CAME OFF OF A DIESEL so he sold it as a diesel starter so someone got screwed... can you put up a few pics of the starter you have?
