JD1010 Crawler Diesel Starter 9 or 10 tooth
In trying to find a starter for my 1010, the part #s 1107573 ( what I pulled out) and the replacement # AT17411T both list a 9 or 10 tooth drive gear depending on where you look. The actual one removed (1107573) has 10 teeth. Don't know if this was a replacement or not. Dumb question - should I match the 10 tooth starter I pulled out or could it be wrong. I have no gear grinding. Would a 9 tooth work? Take it easy on this newby (':shock:')
- DukeofDeere
Gas is 10
Diesel is 9
Duke
Diesel is 9
Duke
- DukeofDeere
I believe the 1010s like the 2010s were originally configured to be 12V positive ground, although that would not have stopped someone from converting to 24V.
24 volt was an option, I have never seen one still in that configuration though.
Good catch, I should have said 1010, sorry.
Wal, down here in Texas the way I read the link title it says diesel!
- DukeofDeere
before you sent it out for REBUILD you should make sure you have a diesel starter a gas starter will fit the diesel i have seen a few diesels with gas starters on them... seen one on ebay told the guy it was a gas he said it CAME OFF OF A DIESEL so he sold it as a diesel starter so someone got screwed... can you put up a few pics of the starter you have?
Users browsing this forum: No registered users and 184 guests
