2010 Water Pump Kit
Dozerparts
2010 Water Pump Kit
Post by Dozerparts » Fri Sep 20, 2013 4:54 am
Hi All,
I'm looking to buy a Water Pump kit for a 2010 crawler.Engine # T17513T.
Anyone know where I can get one?
thanks,
Jim
Post by jtrichard » Fri Sep 20, 2013 12:20 pm
there is no kit that i know of .... the bearing and seal can be had from other sources the impeller is JD ONLY and is at least $100 last i knew....and the seal surface on the impeller wears and wont seal so good luck impeller part# T574T seal# R32622R retainer #R1529R bearing #JD8582
Post by Lavoy » Fri Sep 20, 2013 2:56 pm
I can get kits, but they don't include the impellor. Right or wrong, I have faced some impellors in the lathe and reused them.
Post by Tigerhaze » Fri Sep 20, 2013 3:50 pm
Lavoy wrote: Right or wrong, I have faced some impellors in the lathe and reused them.
I guess if it doesn't leak or blow apart then it is right :lol:
Post by Lavoy » Fri Sep 20, 2013 3:53 pm
Don't know if I would go that far, but it has worked in the past. :lol:
Post by jtrichard » Fri Sep 20, 2013 10:18 pm
if they are not wore to bad you can reface but to much and you dont get the pressure on the seal it needs
shinnery
Post by shinnery » Sat Sep 21, 2013 12:36 am
Assuming the impeller is brass or bronze, could you build them up with acetlyne torch and brass then turn then down smooth?
Post by jtrichard » Sat Sep 21, 2013 11:02 am
cast iron impeller
DukeofDeere
Post by DukeofDeere » Sat Sep 21, 2013 12:18 pm
Even better to build up with braze and turn it down to fit.
Duke
Post by Lavoy » Sat Sep 21, 2013 5:53 pm
I would assume brass would be too soft and the seal would eat it in not time.
DukeofDeere
Post by DukeofDeere » Sat Sep 21, 2013 6:03 pm
Better than nothing.
I think brass would last with a quality Antifreeze.
Post by jtrichard » Sat Sep 21, 2013 7:07 pm
one problem with brazing it up is the shaft bore shrinking if you did not have right size reamer then you might split it pressing it back together
