2010 Water Pump Kit
Dozerparts
2010 Water Pump Kit
Post by Dozerparts » Fri Sep 20, 2013 4:54 am
Hi All,
I'm looking to buy a Water Pump kit for a 2010 crawler.Engine # T17513T.
Anyone know where I can get one?
thanks,
Post by jtrichard » Fri Sep 20, 2013 12:20 pm
there is no kit that i know of .... the bearing and seal can be had from other sources the impeller is JD ONLY and is at least $100 last i knew....and the seal surface on the impeller wears and wont seal so good luck impeller part# T574T seal# R32622R retainer #R1529R bearing #JD8582
Post by Lavoy » Fri Sep 20, 2013 2:56 pm
I can get kits, but they don't include the impellor. Right or wrong, I have faced some impellors in the lathe and reused them.
Post by Tigerhaze » Fri Sep 20, 2013 3:50 pm
Lavoy wrote: Right or wrong, I have faced some impellors in the lathe and reused them.
I guess if it doesn't leak or blow apart then it is right :lol:
Post by Lavoy » Fri Sep 20, 2013 3:53 pm
Don't know if I would go that far, but it has worked in the past. :lol:
Post by jtrichard » Fri Sep 20, 2013 10:18 pm
if they are not wore to bad you can reface but to much and you dont get the pressure on the seal it needs
shinnery
Post by shinnery » Sat Sep 21, 2013 12:36 am
Assuming the impeller is brass or bronze, could you build them up with acetlyne torch and brass then turn then down smooth?
Post by jtrichard » Sat Sep 21, 2013 11:02 am
cast iron impeller
DukeofDeere
Post by DukeofDeere » Sat Sep 21, 2013 12:18 pm
Even better to build up with braze and turn it down to fit.
Duke
Post by Lavoy » Sat Sep 21, 2013 5:53 pm
I would assume brass would be too soft and the seal would eat it in not time.
DukeofDeere
Post by DukeofDeere » Sat Sep 21, 2013 6:03 pm
Better than nothing.
I think brass would last with a quality Antifreeze.
Post by jtrichard » Sat Sep 21, 2013 7:07 pm
one problem with brazing it up is the shaft bore shrinking if you did not have right size reamer then you might split it pressing it back together
Users browsing this forum: Google Adsense [Bot] and 16 guests
