Been using my 1966 350 for clearing over grown brush where I live was working in third gear back blading left over branches put into forward to make another pass a very loud sound like a slipping spline or coupling and no movement of the machine. Reverser I believe is working if I have trans in neutral reverser in either forward or reverse I get grinding when trying to select a gear so I am assuming the problem lies behind the reverser. engine is strong reverser could be smother shifting but works well already rebuilt both steering clutches hydraulic pump & control valve new re core on radiator three new injectors looks like I will be doing an almost complete dismantle to fix the problem. Has any one had this same misfortune as me.
I am a retired heavy truck Master Mechanic and worked on heavy equipment also but really did not need this to happen
Not a happy camper!!!
A Bad Day
Coupling
There is a coupler between the reverser and transmission. My guess it is stripped, fairly intensive project to fix.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
a bad day repair complete
tried out my 350 today doing some clearing lots tighter now that all of the bolts are tight and all are where they should be pictures to follow when I figure out hot to post
new alternator
Had been having alternator issues on my 350 had a denso when I bought the machine with the wrong size pulley had to put a disconnect switch because it would drain batteries when it was not running . found a new single wire from DB Electrical best part $ 71.00 including shipping with the 5/8 pulley .[/code]
