A Bad Day
jsal
A Bad Day
Post by jsal » Tue May 14, 2013 6:47 pm
Been using my 1966 350 for clearing over grown brush where I live was working in third gear back blading left over branches put into forward to make another pass a very loud sound like a slipping spline or coupling and no movement of the machine. Reverser I believe is working if I have trans in neutral reverser in either forward or reverse I get grinding when trying to select a gear so I am assuming the problem lies behind the reverser. engine is strong reverser could be smother shifting but works well already rebuilt both steering clutches hydraulic pump & control valve new re core on radiator three new injectors looks like I will be doing an almost complete dismantle to fix the problem. Has any one had this same misfortune as me.
I am a retired heavy truck Master Mechanic and worked on heavy equipment also but really did not need this to happen
Not a happy camper!!!
JWB Contracting
Coupling
Post by JWB Contracting » Tue May 14, 2013 8:28 pm
There is a coupler between the reverser and transmission. My guess it is stripped, fairly intensive project to fix.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
rcs110
Post by rcs110 » Tue May 14, 2013 9:00 pm
well I am doing the same pulling the rest of the transmission out this weekend in order to fix the bearings and as of now two gears. :(
1969 350 crawler
t4e3d
jsal
Post by jsal » Wed May 15, 2013 4:31 am
that's my guess also hope both shafts are usable could mean even more work
jsal
a bad day repair complete
Post by jsal » Tue Jun 04, 2013 6:53 pm
tried out my 350 today doing some clearing lots tighter now that all of the bolts are tight and all are where they should be pictures to follow when I figure out hot to post
jsal
new alternator
Post by jsal » Tue Jun 04, 2013 7:15 pm
Had been having alternator issues on my 350 had a denso when I bought the machine with the wrong size pulley had to put a disconnect switch because it would drain batteries when it was not running . found a new single wire from DB Electrical best part $ 71.00 including shipping with the 5/8 pulley .[/code]
Post by jtrichard » Tue Jun 04, 2013 9:30 pm
triod was bad in your old alt
Users browsing this forum: No registered users and 242 guests
