What is the main differences between JD 450 and 450 B's
Rustyslater
Post by Rustyslater » Thu Jul 19, 2012 9:01 pm
What is the main differences between JD 450 and 450 B's ?
The mother Deere have an over lap building them as in did they produce 450's and 450B's at the same time.
Also if any body could help me de-code my SN 15F3M021588T. my sn plate was pretty torn up not realy sure about the first #
Old mechanics never die they just fade away!
Willyr
Post by Willyr » Thu Jul 19, 2012 9:25 pm
former owner of a 1956 420c
Post by Tigerhaze » Fri Jul 20, 2012 8:31 am
Rustyslater
thank you fellers for your help
Post by Rustyslater » Fri Jul 20, 2012 7:02 pm
when looking at that list on the message would you look for sn 021588 or 21588 i dont see any of the other sn's that start with 0 so i assume i would look at 21588
Post by Tigerhaze » Mon Jul 23, 2012 9:08 am
The first 5 letters do not look correct, but assuming the last 6 numbers are it would be a 1966 (straight) 450.
The other place to look up specs for differences between the 450 and 450B (besides the thread I posted) is the spec sheets at Murphy Tractor:
Straight 450 Crawler
http://www.murphyused.com/images/specs/66.pdf
1965 Straight 450 Crawler Loader
http://www.murphyused.com/images/specs/110.pdf
1969 Straight 450 Crawler Loader
http://www.murphyused.com/images/specs/111.pdf
1971 450B Crawler
http://www.murphyused.com/images/specs/86.pdf
Rustyslater
thanks
Post by Rustyslater » Mon Jul 23, 2012 9:44 pm
I got a service manual today when i get home. it will be tear down the steering clutches. and find a right rear finel drive some body let it (the finel) fill with water and it cracked.
thanks for the links and stuff.
JWB Contracting
Which model do you have?
Post by JWB Contracting » Mon Jul 23, 2012 9:59 pm
I believe that there was a change up on the steering clutches, clutch housing and the final drives on the "B" series of 450's. You will known once you pull the steering clutch.
Either way, a final drive case or complete bolt on shouldn't be hard to find.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Users browsing this forum: No registered users and 266 guests
