What is the main differences between JD 450 and 450 B's
Rustyslater
What is the main differences between JD 450 and 450 B's ?
The mother Deere have an over lap building them as in did they produce 450's and 450B's at the same time.
Also if any body could help me de-code my SN 15F3M021588T. my sn plate was pretty torn up not realy sure about the first #
Old mechanics never die they just fade away!
- Willyr
former owner of a 1956 420c
Rustyslater
thank you fellers for your help
when looking at that list on the message would you look for sn 021588 or 21588 i dont see any of the other sn's that start with 0 so i assume i would look at 21588
The first 5 letters do not look correct, but assuming the last 6 numbers are it would be a 1966 (straight) 450.
The other place to look up specs for differences between the 450 and 450B (besides the thread I posted) is the spec sheets at Murphy Tractor:
Straight 450 Crawler
http://www.murphyused.com/images/specs/66.pdf
1965 Straight 450 Crawler Loader
http://www.murphyused.com/images/specs/110.pdf
1969 Straight 450 Crawler Loader
http://www.murphyused.com/images/specs/111.pdf
1971 450B Crawler
http://www.murphyused.com/images/specs/86.pdf
1971 450B Crawler
Rustyslater
thanks
I got a service manual today when i get home. it will be tear down the steering clutches. and find a right rear finel drive some body let it (the finel) fill with water and it cracked.
thanks for the links and stuff.
JWB Contracting
Which model do you have?
I believe that there was a change up on the steering clutches, clutch housing and the final drives on the "B" series of 450's. You will known once you pull the steering clutch.
Either way, a final drive case or complete bolt on shouldn't be hard to find.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Users browsing this forum: No registered users and 35 guests
