Left hand bell crank,need one
Hello Lavoy,, I was hoping you might be able to help me out with a left hand bell crank Part# T14373T for a pre 42000 2010 crawler. While working on the assembly I discovered the bottom arm was broken off nowheres to be found I would guess it might be like looking for hens teeth .Any help I would be gratful Thanks JDjoePA in NEPA,, PS I am ready to order some parts if you let me know the most helpful way for you, I call call you after work tommorrow about 2PM. your time,,,
Lavoy,RE Bell crank,,
Hey Lavoy, I was able to find and get that Bell crank but wiil stiill need some parts will try to ring you Mon. 26th if I get off from work at a semi normal time thanks JDjoePA
