Left hand bell crank,need one
JDjoePA
Post by JDjoePA » Thu Mar 22, 2012 6:37 pm
Hello Lavoy,, I was hoping you might be able to help me out with a left hand bell crank Part# T14373T for a pre 42000 2010 crawler. While working on the assembly I discovered the bottom arm was broken off nowheres to be found I would guess it might be like looking for hens teeth .Any help I would be gratful Thanks JDjoePA in NEPA,, PS I am ready to order some parts if you let me know the most helpful way for you, I call call you after work tommorrow about 2PM. your time,,,
Post by Lavoy » Fri Mar 23, 2012 9:04 am
Slight possibiliby I have one at the farm, but nothing here. I probably won't be out there for a while, but can check when I am there.
Call or e-mail, whichever works for you.
JDjoePA
Lavoy,RE Bell crank,,
Post by JDjoePA » Sat Mar 24, 2012 12:13 pm
Hey Lavoy, I was able to find and get that Bell crank but wiil stiill need some parts will try to ring you Mon. 26th if I get off from work at a semi normal time thanks JDjoePA
Post by Lavoy » Sat Mar 24, 2012 12:33 pm
Sounds good.
Users browsing this forum: No registered users and 152 guests
