831 Loader on 440icd
Does Deere still make rebuild kits for the hydraulic cylinders for the 831 loader? I have a user manual on the loader but not a parts manual. Need to rebuild one bucket cylinder (the short 5" diameter cylinder) and could not locate the 831 loader on JDParts. Have not opened up the cylinder yet but is was leaking badly before I started rebuilding the crawler.
Thanks. I may have to go to a shop since I can not get the cylinder apart. I removed the cylinder from the crawler and removed the spanner nut. So far so good. The manual indicates to press the cylinder head in to provide clearance to remove the snap ring. I can not budge the cylinder head. Tried bar clamps and hitting it with a lead hammer, it will not move. Sometime in the past someone welded the rod end on, but the weld has cracked so the plan is to remove the rod end, which will then allow me to slide a sleeve around the rod, put the entire cylinder in a hydraulic press, and to try and push in the cylinder head.
Suggestions!
Suggestions!
