Detroit oil pressure
Howard Yoder
What kind of oil pressure should the 253 run after it has worked for an hour or two. Mine drops almost to nothing like around 10. When i first start it it reads around 45. Thanks
I asked the area detroit rep about this once his answer was you had better be using 50 weight in summer the 53 series had a verry poor oil pump to begin with .A new pump is not much better than an old one.The detroit book says 6 pounds minimum pressure but I would not idle at this for long if it was my motor My two detroit s use shell rotela t 50 weight only The only motors I use shell in and nothing else uses 50 weight I guess try this as this thing says all 53-71-92 & 110 series motors This pretty well covers all two strokes I guess? digitup
Howard Yoder
