Hoe on 350 crawer
Hoe on 350 crawer
I tryed to hook up my hoe first time today I lifted the bucket up couldn't get under it . I had to lift the hoe up an block the backhoe, don't know if it will work. what is the procedures? i read where some one said it only takes 5 minutes.
http://www.youtube.com/watch?v=Nf7QqrrKrmY this what im looking for . I have no seat fot it but i have old very nice barber chair im useing with the swivel pedestal off . Brain storm thank you lavoy.
Its strange I can,t find cylinders for the swing. It should work like this 1 on U Tube http://www.youtube.com/watch?v=Nf7QqrrKrmY Thank you Lavoy. It must be a gear box with rack an pinon .
Matte.Im aussuming eveything will work like it suppose to. I have one out rigger valve that was froze up still sticky , out riggers an boom are the key to connect an disconnecting the hoe "wish me luck". It would be a mess if it fliped over an ripped a hose off or two. I'll strong arm it then hook the hoses up. Thank you
Kenp. Thank you for the information on the open an closed loop hyd system.The guy that delivered ithe tracker and hoe for 3200$ said it worked but the hook up fitting was broken. He wanted me to back it off his trailer with hoe not working NO Way he was lucky. I can't repair the hoe unless It's hooked up an hyd oil going through the system evey thing could be ok an ready to go. For safety, I want the hoe on the machine an secured. The hoe is set where the tractor can get under the hooks and maybe raising the tractor bucket will let me pin up. Gerald
Kenp. After strong arming a few hours to make the connection to the 40 year old tractor an hoe. I decided to make the connection like suggested to me, the stablizer did stick a little other then been chicken it only took 10 minutes.. It's a really powerfull machine digging through rock an clay like nothing, Hyd oil leaking from the back of the control manifold. that shouldn't to hard to fix.
I took the valve bank off marking all 12 hoses it was heavy, 3 bolts and the 6 manifolds came apart. I found 0 rings missing an broken . I fixed a sticking out rigger spool . I hope to have the control on an working after Thanksgiving. I got all the 0 rings at Truevalue hardwere, there thin 0 rings, Truevalue was my last hope.
The valve assembly is back on the hoe and hooked up to the tractor. It was a 5 minute job. I used the brute a few hours . For no reason the right out riggger valve locked up in the up position. I,m hopeing to remove the cap on bottom of valve an loosen the spring, will that work ? No way am I going to strong arm that thing again. Thank you Gerald.
Users browsing this forum: No registered users and 252 guests
