PTO Drive Shaft
YooperBart
PTO Drive Shaft
Post by YooperBart » Mon May 17, 2010 2:17 am
Anybody know where I could acquire one for a mid-50's era John Deere Model 420 crawler?
I will not put my name on a product that does not have in it, the best that is in me. -- John Deere
Post by Lavoy » Mon May 17, 2010 8:16 am
I am out of used, can get new reproductions.
dr.fireman10
Post by dr.fireman10 » Mon May 17, 2010 8:21 am
They should be readily available. . .
Im sure Lavoy could hook you up with a good used or rebuilt one, Ive also seen them listed on E-Bay from time to time.
Do you need the complete stub shaft unit, housing and all, to bolt up to the back? Make sure the three ears (the bolts pass thru for mounting) on your housing have not been broken/repaired if you are paying a premium price.
I have some used pieces around left over from my wheel tractor projects (basically the same parts). Id ask $50 for just the PTO shaft, $150 for a shaft and good unbroken housing. The seals/bearings are readily available for a rebuild from John Deere and aftermarket suppliers.
Good Luck! Dave
JD 430C 40V 420S 430S 430W 430T 435 630S
