450b steering isssues
- 40C crawler
Hi there, I have a 450b with some steering issues. This site has helped me a ton so far on this machine so thanks in advance. The issue is no left turn at all. I can pull as hard as i want and feel no resistance and the left tracks will not slow. Im figuring on it being the steering clutch. Not quite warm enough to start working on it but am going to start soon. Was wondering if i could get some guidance on my situation. This is a fantastic running machine. i am very impressed with its power, just need to turn.
jd 450b loader
It may be your left brake band as well.
Even if you had a stuck steering clutch, you should be feeling resistance from the brake band engaging when you pull the left steering lever.
I don't have a 450B, but there should be an access plate that you can use to inspect the brake/clutch areas. Just my $0.02.
Users browsing this forum: No registered users and 270 guests
