420 steering clutch
lrm37
420 steering clutch
Post by lrm37 » Mon May 11, 2009 12:39 pm
The left steering clutch on one of my 420 crawlers is slipping, I have heard of putting in an extra fiber disc,has any one had any experence with this ? Larry
5-420crawlers, 5010 dirt scraper, eimco power horse, 40 w, 420 w, 3-D4 LeTourneau Airborne Tournapulls
Post by Lavoy » Mon May 11, 2009 12:48 pm
It may work, it may not work. I know I sell steering clutches, but I feel it is a total waste of time. It is too much work to pull final drives, why run the risk of having to do it all over again. Just got off the phone with someone that has pulled a 350 final 4 times after fooling with used parts, not the fifth time. The other consideration is the pressure plate springs may be weak, no amount of clutch discs will cure that, same thing if the fibers are oil soaked.
lrm37
420 steering clutch
Post by lrm37 » Mon May 11, 2009 1:28 pm
I understand about the preasure plate and oil soaked disc. Just curious about the extra disc
Post by Lavoy » Mon May 11, 2009 4:18 pm
I missed a word in your post, I was thinking steel disc, you mentioned fiber disc. There is not enough room to add a fiber disc. If there is enough wear, you can get another steel disc in, but not a fiber.
I see by your signature line you have a few D4 scrapers, my brother had two of them.
