manifold paint
mgbuddydad
manifold paint
Post by mgbuddydad » Sun Apr 05, 2009 11:51 am
Is there any paint that will truly hold up over time on a two cylinder exhaust manifold ? Have a 40 that will glow dark cherry red in the dark, and these vertical 2 cylinders seem to eat manifolds.
Buddy
1959 440 IC
Post by JD440ICD2006 » Sun Apr 05, 2009 2:14 pm
Want to make sure that you have the carb set correctly. If too lean, the manifold gets even hotter than normal.
As for paint, a well applied "1,200 F"should be on for a while.
Lu47Dan
Post by Lu47Dan » Mon Apr 06, 2009 10:01 am
1956 420C with GSC blade
Pistonman
Post by Pistonman » Mon Apr 06, 2009 10:01 pm
I like the look of the cast iron color heat paint, I think you can get it at NAPA.
Users browsing this forum: No registered users and 217 guests
