Is there any paint that will truly hold up over time on a two cylinder exhaust manifold ? Have a 40 that will glow dark cherry red in the dark, and these vertical 2 cylinders seem to eat manifolds.
Buddy
manifold paint
manifold paint
1959 440 IC
- JD440ICD2006
Want to make sure that you have the carb set correctly. If too lean, the manifold gets even hotter than normal.
As for paint, a well applied "1,200 F"should be on for a while.
Here are a some high temperature paints
http://www.por15.com/BLACK-VELVET/productinfo/BVG/
http://www.por15.com/FACTORY-MANIFOLD-G ... info/FMGG/
http://www.por15.com/POR-20-ALUMINUM/productinfo/P2G/
http://www.eastwoodco.com/shopping/prod ... ductID=733
I have not used any of them , so I can not comment on their effectiveness . Dan
1956 420C with GSC blade
Users browsing this forum: No registered users and 203 guests
