what manual do i want
Hello, this is my first post in this forum. I recently bought a 350BE 132140. [my first dozer] I would like to get a manual, that shows all the lubrication/grease point on the machine. I could see me missing one or two not knowing all their locations. Does the operators manual show these, or do I need the service/technical manual?
Re: what manual do i want
Welcome to the Boards.
The Operator's Manual is the one with the info you are looking for. For the most part service/technical manuals do not included normal maintenance details which operators and owners are expected to take care of.
Thank you for the response. I am off to find one.
You should be looking for John Deere publication # OMT46859 for your crawler tractor. OMT38742 is the JD publication number for the 6305 inside dozer blade on a 350B.
Lavoy might have these in his store, or might be able to get them for you, if you want to check with him.
Well, I received the manual today, unfortunately the one I got om-t40196 does not have any information on lubrication points. so wasted money there. I will search out the other manual that was recommended and see what I get.
OMT40196 is the Operator's Manual for just the 6300 series blade, not the crawler. (And it does have the lubrication info for the blade.
Use this link to go to the JD Bookstore for Construction and Forestry Equipment.
https://www.johndeeretechinfo.com/
On that homepage type 350B in the Model box then click the search icon at the right of the center search box. That should open a list of manuals available for the 350B including the blades. OMT46859 is the first one in the list when I do these steps. Click on download and it will download a free pdf copy to your computer, which you can save and print from when you wish.
Thank you, I went to the enclosed link and downloaded just what I was looking for. I will spend some time reading through it and hopefully get most of my questions answered.
