Curious...what inside blade mounts to 440?
See a 1010 with inside mount out for parts..will that fit ?
Also what all does the 62 blade fit??
1010 inside mount blade
Re: 1010 inside mount blade
Referencing the old WetWare here....
The 62 fits the 420 and 430.
The 63 is the 62 replacement for the 440 - different crossbars so the 62 won't fit the 440.
The 64 is the PAT blade for the 440.
The 1010 sees things change again and so a new set of blades, which I don't recall the model numbers of.
are the center frames marked by number?..how know which is which..book?
- jimmydiesel
The 6 way hydraulic blade for a 1010 is a 612. It is similar to a 64. It will not just swap over to a 440. Can it be made to work ???
I was planing to do this swap but found a 440 with the 64 so never started the change.
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
440 ICD 831 Loader
440IC 831 Loader
I seem to recall different diameters of the cross bars as well as square ones vs round ones. So, some work needed there to cross fit stuff. And, are there differences in the overall widths and lengths between the various models of blade frames?
I've always just went with the concept that none of these cross fit.
