455E
Rev2018
455E
Post by Rev2018 » Thu Jun 20, 2024 5:10 pm
Have a 87’ 455E. Had a stuck go through the radiator. Looks like it has a smaller radiator on front that, I believe is an oil coolant? My question is it looks like oil is coming out of the radiator? Any thoughts on what might be going on? Thanks in advance.
Re: 455E
Post by Jim B » Thu Jun 20, 2024 5:45 pm
Welcome to the Boards. The transmission oil cooler should be mounted on the right side of the radiator. It is the same height and thickness as the radiator and about 5 inches wide. It is an oil to air heat exchange unit, the oil is in the core tubes. No engine coolant is used in it. Sounds like you have a hole in the oil cooler.
Rev2018
Re: 455E
Post by Rev2018 » Thu Jun 20, 2024 9:51 pm
Thanks for input
