Working through this new to me 440ICD. The 831 loader is sloppy with a lot of play at the lower bushing on the forward bell crank. I pulled the out big bolt that holds the arm to the bushing. The bushing seems tight, but there is side to side slop. I see shims on the inside between the bolt with washer and lift arm. They're 1.75" ID and 5.25" OD. I see no listing in the parts manual for a shim. Probably 1/32" or 1/16" thick. Anyone know where to source these? Make them myself?
Thanks.
Mike P.
831 Loader Shims
Re: 831 Loader Shims
With enough hunting you can likely find some that will work somewhere. However, it is easiest is to just make what you need.
