Does anyone have experience rebuilding leaking valves on a 93A backhoe attachment? I just restored mine cosmetically, made some new levers, replaced all the hoses, etc. then I hooked it the crawler and began operating it for the first time and noticed one of the valves under the operator levers (in the center) leaking from the top where the rod goes in.
Is this going to be a long drawn out process or is it a simple repair?
93 Series A Backhoe Leak
cordlesscarpenter
Re: 93 Series A Backhoe Leak
There should be o-rings as I recall. Not an easy task but not overwhelming either. Just messy and a bit time consuming.
cordlesscarpenter
Do the valves come apart individually from the bottom or do you have to remove the entire bank of valves?
I imagine disconnecting the lever linkage at the top, removing the shaft/guts from the bottom, replacing a bunch of O-rings and re-assembling. Does that sound familiar or am I way off?
Thanks!
Darrell
