93 Series A Backhoe Leak
cordlesscarpenter
Post by cordlesscarpenter » Sun Jun 05, 2022 4:09 pm
Does anyone have experience rebuilding leaking valves on a 93A backhoe attachment? I just restored mine cosmetically, made some new levers, replaced all the hoses, etc. then I hooked it the crawler and began operating it for the first time and noticed one of the valves under the operator levers (in the center) leaking from the top where the rod goes in.
Is this going to be a long drawn out process or is it a simple repair?
LeonardL
Re: 93 Series A Backhoe Leak
Post by LeonardL » Mon Jun 06, 2022 8:44 am
There should be o-rings as I recall. Not an easy task but not overwhelming either. Just messy and a bit time consuming.
cordlesscarpenter
Post by cordlesscarpenter » Mon Jun 06, 2022 9:06 am
Do the valves come apart individually from the bottom or do you have to remove the entire bank of valves?
I imagine disconnecting the lever linkage at the top, removing the shaft/guts from the bottom, replacing a bunch of O-rings and re-assembling. Does that sound familiar or am I way off?
Thanks!
Darrell
Users browsing this forum: No registered users and 927 guests
