Adding PTO to 420C
tobaccofarmer
Adding PTO to 420C
Post by tobaccofarmer » Wed Dec 02, 2020 7:52 pm
Hey guys was wondering on a 420C that has lever already up beside gear selector how much is involved with adding PTO shaft from rear ? Is it just the rear housing swap with hole for shaft and shaft itself or do you have to spit tractor ? Thanks George
50 MC 11526
50 MC 12103
50 MC 12147
52 MC 15855
52 MC 18039
53 40C 61623 (3) roller
54 40C 62435 ALL FUEL (4) roller 3 point hitch
55 40C 70680 (5) roller 3 point hitch
gus
Re: Adding PTO to 420C
Post by gus » Wed Dec 02, 2020 9:15 pm
Just pull the plate off and bolt the pto on.
Bret4207
Post by Bret4207 » Thu Dec 03, 2020 7:46 am
Yup, just realize that the PTO isn't going to run 540 RPM at what I'd call normal crawler speeds. I ran a bush hog off mine and had to gear down and up the engine RPMS by a lot to get effective work done.
40C, 420C, 1010C-L-BH, Cat D4
tobaccofarmer
Post by tobaccofarmer » Thu Dec 03, 2020 10:22 am
Was planning on generator so no loss of HP for power train whatsoever . Thanks guys
50 MC 11526
50 MC 12103
50 MC 12147
52 MC 15855
52 MC 18039
tobaccofarmer
Post by tobaccofarmer » Thu Dec 03, 2020 6:33 pm
Found a pto shaft but on the end that mates to transmission inside gear housing looks like a cotter pin or bolt goes on that end .wondering if it’s as easy as all going in from rear . I’ll have to pull parts book and see what it shows .
50 MC 11526
50 MC 12103
50 MC 12147
52 MC 15855
52 MC 18039
deeretails
Post by deeretails » Fri Dec 04, 2020 7:22 am
You have the lower plate off, right?
tobaccofarmer
Post by tobaccofarmer » Fri Dec 04, 2020 7:32 am
Not yet, was waiting until I knew for sure it all can be installed from rear only.
50 MC 11526
50 MC 12103
50 MC 12147
52 MC 15855
52 MC 18039
Users browsing this forum: No registered users and 452 guests
