Adding PTO to 420C
tobaccofarmer
Adding PTO to 420C
Hey guys was wondering on a 420C that has lever already up beside gear selector how much is involved with adding PTO shaft from rear ? Is it just the rear housing swap with hole for shaft and shaft itself or do you have to spit tractor ? Thanks George
50 MC 11526
50 MC 12103
50 MC 12147
52 MC 15855
52 MC 18039
53 40C 61623 (3) roller
54 40C 62435 ALL FUEL (4) roller 3 point hitch
55 40C 70680 (5) roller 3 point hitch
50 MC 12103
50 MC 12147
52 MC 15855
52 MC 18039
Re: Adding PTO to 420C
Just pull the plate off and bolt the pto on.
Yup, just realize that the PTO isn't going to run 540 RPM at what I'd call normal crawler speeds. I ran a bush hog off mine and had to gear down and up the engine RPMS by a lot to get effective work done.
40C, 420C, 1010C-L-BH, Cat D4
tobaccofarmer
Was planning on generator so no loss of HP for power train whatsoever . Thanks guys
50 MC 11526
50 MC 12103
50 MC 12147
52 MC 15855
52 MC 18039
50 MC 12103
50 MC 12147
52 MC 15855
52 MC 18039
tobaccofarmer
Found a pto shaft but on the end that mates to transmission inside gear housing looks like a cotter pin or bolt goes on that end .wondering if it’s as easy as all going in from rear . I’ll have to pull parts book and see what it shows .
50 MC 11526
50 MC 12103
50 MC 12147
52 MC 15855
52 MC 18039
50 MC 12103
50 MC 12147
52 MC 15855
52 MC 18039
deeretails
You have the lower plate off, right?
tobaccofarmer
Not yet, was waiting until I knew for sure it all can be installed from rear only.
50 MC 11526
50 MC 12103
50 MC 12147
52 MC 15855
52 MC 18039
50 MC 12103
50 MC 12147
52 MC 15855
52 MC 18039
Users browsing this forum: No registered users and 67 guests
