440 track questions
ksfunk
440 track questions
Post by ksfunk » Thu May 07, 2020 7:40 am
I am a newbie at this but I have a 440 with well worn tracks. I have access to a set of 350 tracks that are in good shape. Can I use the 350 tracks? what will it require to make the switch? my 440 tracks are 4 bolt.
Re: 440 track questions
Post by Lavoy » Thu May 07, 2020 7:57 am
You will need to rerim your 440 sprockets with 350 rims, pads will bolt on if you need to transfer pads.
ksfunk
Post by ksfunk » Thu May 07, 2020 2:30 pm
How do I rerim? can I use the sprockets off the 350 or are there rims made to weld on?
Post by Lavoy » Thu May 07, 2020 3:21 pm
There are rims out there, but getting quite expensive. Cheapest is cut the rim off of a new 350 sprocket, just like you have to cut the rim off of your old sprocket.
ksfunk
Post by ksfunk » Thu May 07, 2020 3:45 pm
Thanks for your help greatly appreciated
dtoots1
Post by dtoots1 » Fri May 08, 2020 2:35 pm
search this site and you can find info and probably pics of the changes to do that.....
Users browsing this forum: No registered users and 180 guests
