440 track questions
440 track questions
I am a newbie at this but I have a 440 with well worn tracks. I have access to a set of 350 tracks that are in good shape. Can I use the 350 tracks? what will it require to make the switch? my 440 tracks are 4 bolt.
Re: 440 track questions
You will need to rerim your 440 sprockets with 350 rims, pads will bolt on if you need to transfer pads.
How do I rerim? can I use the sprockets off the 350 or are there rims made to weld on?
There are rims out there, but getting quite expensive. Cheapest is cut the rim off of a new 350 sprocket, just like you have to cut the rim off of your old sprocket.
Thanks for your help greatly appreciated
search this site and you can find info and probably pics of the changes to do that.....
Users browsing this forum: No registered users and 197 guests
